Avensis 2006 computer
FungleJunk57
Hi all,
I have an old 2006 Avensis with an onboard display/computer. The language is stuck in Spanish. Is there anyway of resetting it without taking the Battery terminals off?
This might be helpful.
You might be looking for "adjustes" if it's in Spanish.
Hi Will,To change the language without disconnecting the Battery, you can turn on the ignition without starting the engine and access the settings menu on the display. You can usually navigate this menu using buttons on the steering wheel or near the display. Look for language options, which may be labeled as "Idioma" in Spanish, and select English If the option doesn’t appear,you might need a diagnostic tool to change it.👍
