Goodmorning!
My 2017 with 116.000km has this squeaky noise from the front when I do long bumps or road valleys. I have changed the upper suspension support, connecting rod and steering heads. The anti-roll bar bushes are ok, I have cleaned and lubed the rubber muffler support but nothing has changed
update: the noise comes out when I'm doing the bump in D and in traction, it doesn't make any noise if I'm in N or when I brake on it
the same noise is also on my Yaris D4D 2014 with 140.000km
Just drive it and don’t worry too much.
Some noises are normal.
it's too much noise, it seems that the car is loosing something
it's like a door in a horror film 😄
  • Haha 1
If you have a noise that you are not sure about, you should have it looked at.
If you can't do it yourself, take it to a garage and set your mind at rest.
On the video it doesn’t sound that bad.
Suspension bushes are most common source of noises why going over bumps. Silicone spray and spray each bushes set at a time, drive the car over bumps and listen for the noises disappear. Then you will find from it comes from. Use only silicone spray on rubber and plastics. 👍
yeah I think so, but where are suspension bushes?
on the rear: image.thumb.png.21006d6fb251c0d1d95e1d407998d3cb.png
on the front: image.thumb.png.859d7f16bb71a35fca9ad85bfa04256a.png
Yes, these ones exactly 👌
thank you Tony! 🍻
