Can someone inform me where the starter motor is on a UC is?
kavos
As title. It would be most helpful if a member of this group could post pictures or maybe a schematic illustration? Plus preferably a vid of one being replaced. I have searched the net but not much joy on this model unfortunately. Unless I'm using wrong keywords? TIA
Appologies for the extra 'is' in title
Edited by kavos
grammatical error
Woah I knew that these cars are not so popular but surely?
Hi Paul, apparently the starter motor is located on the driver's side of the engine, towards the lower part of the engine block. It’s mounted near the flywheel, underneath the intake manifold area. To access it, you may need to remove some components like the air intake and any protective undertrays or engine covers. Hope this helps and maybe someone can provide a schematic.👍
