Hello. I've had an ABS issue on my French-built Yaris hatchback aut 1.3 2004 for a good while now.
Issue
- The ABS system kicks in during slow rolls with light pressure on the brake pedal.
To rule out the rear
- A few weeks ago I got both rear wheel bearings changed; it had no effect on the ABS issue. The bearings had to be changed anyway.
Visual inspection
- Last weekend I inspected both front sensor cables for cracks or outer wear.
I noticed that the left one had the number 89543-0D010 in white and the right one had the number 89542-0D010 in yellow.
Question
- Since one is white and one is yellow, does it indicate which one is the sensor OEM? Or are the different colors irrelevant?
Also, the left one looked way newer compared to the right one.
So far
- Been to multiple garages that used different scan tools on the car without being able to tell which wheel is causing the issue.
Other
- Two garages also inspected the tone rings and told me they were completely fine.
I've had the issue with both of my OEM Yaris wheels with nearly new and balaced tires.
I've also changed front and rear brake pads about 6 months ago.
Trying to figure out which front side to focus on first. Thanks!
What brand rear wheel hubs have you fitted?
Do not rule out these because they might have turn to be the main cause of an issue. What faults are displayed on your mechanics scan tools? This is important to start your fault finding.
Hi,The different colours on the sensor cables white and yellow likely do not indicate which is the OEM sensor. They may be part numbers or markings used by Toyota.
Since the left sensor appears newer than the right one, it might be worth checking the right side, especially since you've already had the left sensor inspected and replaced. The issue you describe, with the ABS kicking in at low speeds, often points to a faulty wheel speed sensor or an issue with the tone ring. If the tone rings are ok and you have had both sensors checked, the right sensor might be worth looking at further, or replacing it with a known good one.
Its possible the issue could also be the ABS control module,it may not be correctly be interpreting the signals from the sensors, especially if the diagnostics tools were unable to pinpoint the problem. 👍
LH - 89543-0D010
RH - 89542-0D010
Back to basics
Do a flash test
Link the pins shown below, turn on the ignition and count the flashes of the ABS light it will be a 2 digits 1st number then a pause followed by the 2nd, it will either repeat the code or go to the next code
Edit. i take its a MMT (automated manual) car
I can't remember from the top of my head, but I can look it up. Although the ABS issue started about 9 months prior to changing the bearings.
I'm suspecting that the left one has been replaced at some point before I bought the car, but I'm not totally sure. It sounds wise to start with the right one.
I have been noticing the speedometer being jumpy and quite inaccurate at low speeds. It's not unusual that the displayen speed is stuck at like 8 km/h and then jumps down to 3 or gets stuck at 5 km/h then makes a quick jump to 11. Might be something to that?
3 hours ago, flash22 said:
LH - 89543-0D010
RH - 89542-0D010
Back to basics
Do a flash test
That sounds far from basic—at least to me. I'm not a mechanic of any sort, but I get a feeling I might need some sort of scan tool to sort that out?
Hi - I've had the same problem on my 1998 Avensis 1.8 petrol 7AFE auto for a couple of years now and haven't been able to locate the problem so I've just lived with it.
flash22 - I'm familiar with doing the flash test that you mention (I've done this previously when the engine management light (EML) came on - it was the O2 sensor that needed replacing then). What codes would I be looking for and what would they tell me? Can I use the same pin linking as in your diagram? There are no dashboard lights on now - neither EML or ABS. Thanks.
Following on from my previous post...
From a document I found when I did the flash test previously, I see that the pin linking is the same on  my Avensis (i.e. link pins 4 and 13).
I see also that code 42 is "Speed sensor" - is this the wheel sensor? If so, how do I know which wheel is the problem?
Yes, wheel sensors is also called a speed sensor. It is a magnetic ring built into the wheel hub bearing and poor quality or failed rings can cause exactly an abs malfunctioning and problems. You need a diagnostic reader to find the codes and take it from there.
here some interesting stuff about Toyota speed sensors
During today and tomorrow, I will put a few rounds of penetrating oil on the front ABS sensors bolts to inspect the sensors and remove some of the potential rust where the sensors are seated.
Will update. In the meantime, I'm thankful for any further inputs.
The thread below matches my issue perfectly: very present brake judder at low speed, no constant ABS light, and so on.
do you have that code? does your speedo work ??
flash22 - I haven't checked for code 42 yet. I'll try and do it at the weekend. Yes my speedo works fine. Does the speedo work off the wheel speed sensor(s)?
If you run a diagnostic best to use a tool that can pick up the fault codes similar to dealers tools so it will be easy to find which wheel is at fault.
In general speed sensors on the wheels is only for the abs unit and the speed sensor for the car itself is often mounted on the transmission.
The car ecu uses these two speed sensors inputs to determine the speed of the car and the speed of each wheel so abs can operate correctly. When one or more wheel speed sensor fail or because of bad connectivity the abs likely to become inactive.
Thanks Tony. However as my Avensis was made in 1998 it doesn't have the modern ODB socket so all I have is the 16 pin thing as per the diagram in flash22's post above. The problem is definitely the ABS kicking in at low speeds, however I have no way of telling whether the problem is one of four wheel speed sensors, one of four reluctor rings or the ABS unit itself. I think it would a case of trial and error replacement (which could get expensive and not fix the problem) - unless you have another suggestion?
Or is the 16 pin thing a socket I can plug an ODB reader into?
I think Flash22 can advise better on this matter. I am not sure on 1998 cars obd 2 port is the same as on the newer models.
Old cars really could be a rust and debris the reason for abs issues.
Youtube videos perhaps may help too.
YarisPie - the only tool you need to do a flash test is a paper clip bent to the right shape. I did this yesterday on my 1998 Avensis and it confirmed what I thought - i.e. no codes were present. EML is not on (and never has been). I think the 16 pin connector on my car is too old to support ODB.
Perhaps Tony is right - could be rust/debris in the wheel speed sensor/recluctor ring area?
obd2 was a standard from 1996, diesels from 2003-2005 before that its obd1 that used a different connector
Pre 1995
Thanks flash22 - but even if my Avensis port is ODB compliant and if I could get an ODB reader that works with it then I think that as there are no codes present (from my flash test) then that wouldn't help - as an ODB reader would also report nothing?
