USB socket input
152bobby
Does anyone know if the usb port next to the drivers heated seat switch can be easily popped out and rotated, I have a 90 degree cable that I want to use, but it covers the heated seat switch a bit.  I need it sticking out the other way towards the left...either that or I can easily just buy a left sided 90 degree cable !!
the whole panel is just clipped in place you can pop it out with a trim tool
example pics
https://www.ebay.co.uk/itm/326274280828
iirc the port is keyed but nothing dremel wouldn't cure
This is for the hatch but it shares the same ports/lights, im working on another trim atm
