Rear fog light switch needed for Corolla 1999
Erin Nally
My Corolla has failed on rear fog light switch not working. Can’t seem to find a replacement anywhere.
rear fog light switch for 1999 corolla.
thanks in advance.
Toyota have them on "sale" at just £121  ,   bargain  - Not !
https://toyotadirectparts.co.uk/parts/toyota-corolla/corolla-mk8-1995-2001/exterior-interior-corolla-mk8-1995-2001/toyota-corolla-mk8-1995-2001-rear-fog-lamp-switch/
As you can see it does show the toyota Part number so that may make your search easier.
However a Switch is a Switch so if you are handy with such wiring, or know someone who is, then see no reason why not securely fitting a Toggle or similar Illuminated when On switch from the below list cannot do the job and get you past the test.
If going for one of the Push switches it needs to the the Latching Type , eg Push for On, Push again for Off,  not the more common Momentary ones.
https://cpc.farnell.com/c/electrical-lighting/plug-in-timers-time-switches/12v-switches/12v-illuminated-switches
