Proace verso heater problem
Paul Limerick
Hi all. Right I got a 2018 proace verso. 200km. 2 ltr diesel . The problem is this. When the van is up to temperature, it will only blow hot air out the passenger side. Flushed the matrix if that's what it's called with a garden hose. Nothing exciting came out of it. Done it back and forth a few times. Then after bleeding it. Went for a drive. Got it up to temperature. Yippee I had heat. Short lived. About two minutes it started blowing cold again. Any ideas or help would be appreciated. Thanks all
