Shark Antenne
Aldino
Last night I wanted to park the car in the duplex garage and I knocked off the antenna on the roof of the car. there is on to e buy a used antenna on the internet and I thought I would exchange it together with a friend.the problem is because now I have an error on the obd 2 telematics and I think that the e call system no longer works for me.  I have a red light on e call where the button is. I don't think it was red before. Does anyone know where the sim card from the e call system in the Yaris Cross is located. Is it in the antenna that looks like a shark.
There is no sim card - its an electronic e sim.
Does the part number on your replacement antenna match the part number from the vehicles original equipment antenna?
I can't find the number, I only see two letters LR
you have an error as you killed the antenna, not sure how you managed to knock a shark fin off the roof it must be a very low ceiling in the garage or the door wasn't all the way up
you will have to drop the headlining down to unplug and unbolt the shark fin
86760-0d010
new they come as the base and the cover separately
Is it not sufficient to remove the plastic cover on car ceiling to access to antenna ?
quite possibly on the YC, i forgot about that compared to the MK4, tho it sounds like the op has it removed already
