Morning,
I have a Toyota Corrola spacio 2002 1NZFE on wich the instrument cluster went out and the car wont go past 3th or 4th gear
all the lights on the cluster work but i'm not getting trip counter, fuel gauge, odometer, speedomter and Temp read.
they all went out simultaneously with the transmission.
i've already changed vss (speed sensor twice) checked all the wheel sensors but still did not get this resolved.
does anyone know how to solve this?
have you pulled the codes from the car ?
2002 makes the same car as the european E120 Mk2 Corolla Verso
the codes i got were p0500 and p1760 and yes it is the same car
the p1760 was resolved but the p0500 still keeps popping up even after the changed speed sensors
