Hi all,
Can anyone tell me,
If I start the GT86 with the key fob in range, but leave the key outside the car, can I drive the car away?
Wife has lost BOTH keys and the car is stuck on the driveway.
Thanks in advance.
Yes - once started it will stay running.
Some vehicles will warn you on the display the keyless fob isn't detected / some also beep.
Some vehicles ( 308 T9 I used to own ) will also not allow you to switch the vehicle off easily without the keyless fob being present.
It will normally drive until you stop the car again...not sure on that model if stop/start kicks in it won't re start so i would disable that to be on the safe side.
Many thanks for the swift response. At least I can guess where the key may be!!
Thank you both.
