I have Toyota aygo 2007 semi automatic .I am having a strange problem with Toyota aygo first it started misfire cylinder 1 then I replaced all the plugs then it stopped misfiring for couple of days then again it started to misfire then changed the all coil packs then problem was gone for 2 weeks then same problem again
Check all the connectors they are fine
I have ODB scanner now multiple cylinders are misfiring but it doesn't happened every day some time it will go smoothly one or two days then again engine light will appear on the screen then automatically will go off I am attaching screen shot of my ODB scanner reading
I have cleaned pcv value wasn't that dirty cleaned throttle body and Map sensor as well
