Ignition Sys..
nobbe2556
Hey How would I go about disingaging my ignition system and shutting off the fuel injection. I need to run a few charging tests. I have a '91 Camry w/ the 2VZ-FE 2.5L V6.
Thanks in advance!
disconnect the coil and fuel pump would be 1 solution. :thumbsup:
I believe it's a multicoil fitted to that model so i'm not sure on the ignition side. I have heard of people frying the ignition system if they crankover with the leads removed. Don't know if there is any truth to this. But the fuel system is easy..just pull the injection relay out.
