im rebuilding my celica and need a new engiine. what is the best/quickest that will bolt straight in. id like a turbo if possible
is an SR20 conversion possible??
one guy on here is doing an sr20 still i think.
If you're in Oz then a 1ggte engine would a a simple conversion.
  • 2 months later...
hey. i'm in melbourne and own a 77' ra28 also. if you find a good motor/easily installed, please chek back in! i would be grateful to find out what u use and how much, also where you found it.
also looking for many other parts.
cheers
mrmerlin....
sorry mate, im a laymen :)
1ggte?
1ggte is a twin turbo 2 litre 6 cylinder engine found in certain supras, soarers etc roughly between 1986 and 1992. These engines also come with a supercharger (1ggze) or normally aspirated (1gge). These engines are very common in Oz and you should be able to pick one up fairly cheaply. Here is then UK they are quite scarce but can be found if you know where to look. Here's a link with more info and an installation guide.
http://www.toymods.org.au/Darren/build_notes.htm
great link! thanks...
