How much power has a L54-engine in UK? 90 or 110 hp?
Do you know, why the american L54 have 110 hp?
And the german (euro) L54 only 90 hp.
e.punk
It's EL45, and they all have 93HP and 110TQ unless you have the 5E-FHE
Thats a Cynos (Jap Paseo) these had 5E-FHE which had 110bhp rather than the 5E-FE which didn't. Different ECU, higher compression ratio, different cams, different injectors.
110TQ is torque. that's low RPM power. it's still EL45. 54 to my knowledge doesn't exitst. it's the model type, nothing to do with the engine, and the 5E-FE and 5E-FHE both have the same body style and chassis.
in the US we have to HP figures.
one is @ 93 hp and the other is at 100hp.
the dif between the 2 is because of the gen1 paseo and the (DIS) Gen 2 paseo.
DIS= distributorless ignition system.
