Oil Filter
breezer
:crybaby:
someone must know!! i have a yaris from france, will this oil filter fit?? just baffled by it saying jap spec :arrgg-matey:
Is this the TRD filter you're talking about? (Can't get on Envy's site, takes ages loading)
If so, there is a TRD "Japan" and a TRD "USA" oil filter, this is prolly the difference they're on about.
BTW, regular oil changes with a good quality oil and the regular Toyota filter will likely be of more benefit to you.
Cheers, Yves.
i just like it because its a red filter, will go with my strut brace!!
yeh its the one on envys site for £20, its red, its the TRD oil filter and says jap spec.
so would this mean it will fit my yaris (france) ?
yes it will fit, just make sure to order the correct one, there are (I think) 3 different sizes. you need the smallest ones.(TRD partno 90915-SP000)
Cheers, Yves.
Just select the one you want from the drop down menu, they go on engine size for all UK versions.
£20 each, I think they mean the specification is of higher quality to the standard ones you would normally buy...
on envy performance is there a way of just searching for say all yts products?
i login select yts and seach through different sections but it comes up with all car products!!! :help:
CB
on the homepage, select your car and click go!! wait for the page to reload, then go through the menus on the left hand side and itl bring up all products for your car! if not, select your car again and do the same!
