Overheating Gt4 St185
jonnyb
my gt4 has just started overheating ,
it goes up to just below h and then back down to half after a few mins
then back up again every now and again , more regular the more i drive it
it only started happening a few days ago
any ideas ??
the garage reckon it may be a sticky thermostat , but won't touch it as they don't deal with this type of car
will the thermostat be easy to replace , if so where is it located on the engine ?
as i haven't got round to getting a manual yet ??
any help/advice would be appreciated
thanks
Jonathan
Find the radiator, at the bottom is a big hose that comes back up to the engine, at the top end of that hose is an aluminium housing that bolts to the engine. The thermostat is inside that housing. Its held on by 2 nuts. You would be well advised to fit a new gasket on there too, I think the part number for the gasket is 16325-62010.
make sure you goto toyota for the thermostat and gasket ,usually around £20 , but keeps the job right with the waterworks . dragonville industrial estate minories toyota :thumbsup: ,ask for shaun or michael both a really good guys. :thumbsup:
