Alarm Fitting
Yarizman
Can anyone provide me with the wiring diagram for my yaris T3 2003 model
Im fitting a cliffiord intelliguard 750 alarm & was especially keen to find out how to wire up the central locking & windows (roll up) i.e. what/which are the wire colours to hook up to.
Opened up the drivers side window switch & found the following wires:
Thin green/silver dot wire
Thin brown/white wire
Fat Green/Silver dot wire
Fat Red/Silver dot wire
Fat Red/Silver dot/Blue wire
Fat white/black wire
Fat green/silver dot /white wire
Fat blue/silver dot wire
Also do I need to add a diode in the boot light circuit in order to isolate the dash light? where do I hook up the trunk trigger, at the light in boot or at the Latch switch in the tailgate. What is the wire colour I should be looking for?
Where do I hook up the door trigger & what is the wire colour I should be looking for
thin wires are for the c/lock (-ve trigger)
for the window module you will need to find a power source in that car that is always on, negitve can be anywhere on the door
trial and error with the windows
you will need 4 of the fat wires, I cant remember which ones, if the windows go down then you have the wrong ones, if the window start then stop then you are shorting out the motors
remember the windows will not stop if the there is an object in the way such as a hand or head
