Themostat Location On Gt4 St185
jonnyb
does anybody know exactly where the thermostat is located on the GT4 ST185 ??
I've got it in bits at the moment trying to change it, is it the part on the top right right hand side of the engine looking from the front of the car held on by 2 bolts ???
thanks
Jonathan
on a st202 its at the end of the bottom radiator hose marked on this pic. thermostat is situated in an alloy colored housing shaped a bit like a bell.yours should be basically the same. 3sgeshowingthermostat.jpg
cheers for that, you were spot on , thats exactly where it was
i managed to get it done after taking intercooler and heat shield off
working in tight space , but its done now and not ooverheating anymore
Job done
Jonathan
