celica gt4 sparkplugs
Monster-Mat
i need to know the code / part number for the latest spec celica gt4 plugs.......
need help fast:(
What is the model type is it?
ST165 GT-Four
ST185 GT-Four
ST185 CS/RC GT-Four
ST205 GT-Four
ST205 WRC
Let me know and I will try and find out.
well there actually for the lexus.......while i was at TTE we were discussing spark plugs.........they recomended instead of buying the expensive HKS plugs to get some latest spec celica turbo gt4 plugs....well 6 to be more precise
so i would imagine it will be the last generation of celica gt4...what was the highest bhp version 240 somthing like that isnt it??.......
id appreciate whatever info you can find nick
the only plugs TTE had on there shelf were for the rally cars.............bit much i think
The spark plugs used in the GT-Four, st 165 & ST 185 at least, are platinum
grade 8 plugs.
these are meant to last 60k miles!
part No :90919-01151
they are not cheap though!!!
if that number is no help go to toyota and ask for some plugs for a 1988 ST
165 GT-Four
best bet is to get ngk plus bcp7ev..they are one grade colder, hence the 7
and cost half the cost easily.
Hope that helps
Nick :D
apparently i need the ST205 plugs......
no doubt there even more expensive
do you have a number for them nick.........hopefully there the same ones
I run Bosch F5DC plugs in my 205 (cheapo copper ones). Miles better spark and much cheaper than crappy platinum ones, only downside is you need to change em a bit more frequently. Don't bother with expensive ones unless you go TRD or HKS or Blitz Iridium which are 15 notes EACH! :o
cheers peeps..........
im actually getting brand new toyota GT4 plugs for a £5 each..........not what you know .........its who you know
so £30 for 6 genuin GT4 205 plugs:D
