How Much
vmail
my local supplier charges 55quid for a 1000W wiring kit and they dont sell 2000W wiring kit. how much are 2000W wiring kit?
cheers
what on earth for!
once again max wattage is a pile of pants if your talking about ICE
what are you running exactly? or going to be running
its not for me its for 1800W RMS (thats what ive been told)
like i say its cack
dont worry what wattage it is for the wiring kit! thats a muppet figure!
just go with some good quality oxygen free 4gauge (AWG) power cable
job done
unless a massive system is being built then you can use 2AWG cable but thats getting a bit thick and tricky to work with
if its only got one or two amps 4AWG will be ample
so roughly how much are 4AWG and 2AWG
whats the max you can put throught a 4AWG
there are 2 amps at 1800W would it be better to have 2 4AWG?
good 4AWG is about 8quid per meter
good 2AWG about 13quid per meter
if your using two amps of that sort of caliber id suggest using 2 4AWG cables from the front
better still use a second Battery in the boot, get a split charger and connect the two batts with a length of 4AWG then run a separate feed to each amp from the 2nd Battery
the car is a ford, will I need to upgrade the alternator if I have 2 batteries
so the batteries are connected in parallel by 4AWG
then the amps run of Battery 2?
what are the good makes of split charger? will I still need a power cap?
Give us a clue!, could be anything from a Ka, toa fully loaded ST220 :ffs:
