Seats
houston
the previous owner has changed the old seats for sum leather ones, but theyre not sitting properly, the passenger seat is rubbing the centre console and the drivers seat is more over to door, is there any difference in the models with the seats or will i be able to bodge it a bit? need to know how to take them out for when i do stereo anyway, thanks
na, i thought that at first but after looking at them it seems pretty hard to put them on wrong sides. drivers seat has lumbar support which makes it a bit different
Seat removal is quite straightforward
Drivers side:
Slide seat back.
Remove fuel flap/boot release thingy (2 screws 1 on base under plastic clip and one going backwards towards the seat).
Take off plastic trim cap from other front 'leg' of seat (prise it off with a screwdriver or something whilst squeezing it top to bottom)
Remove 2 bolts from front 'legs'.
Slide seat forward.
Remove 2 bolts from back legs.
Remove bolt from 'bar' on transmission tunnel.
Lift out seat.
Passenger side: repeat above without fuel flap thingy.
