Seats
quodus
i have a 91 gt4 rc and i wonder when you flip the front seats forward to allow access to the back seats, does the entire seat slide/move forward aswell (i'm sure it should) Can anyone enlighten me ?
Maybe you no how to fix it
k i will have another look at the passenger side do you know what kind of cable to look for ? cos something must be disconnected
almost certain it will be a spring of some sort on the pass side.
Yep theres a big spring underneath that hooks to a metal hook at the back left and something further forwards (not sure what). Sorry thats so vague, but if you don't see a large (almost inch diameter) spring then that'll be the problem.
right i think i figured it out its not the spring i need
There is a cable that loops down and goes into a metal half semi circle
on the passenger door side under the seat
if you play around with the seat adjuster you will see that they line up to a metal connecter perfect, but i cant get the lmetal half semi circle to stay in place on the connector . If you follow the loop carefully you will see that it is connected to the side chair tilt handle.Sorry for the incorrect phrasiology but if you have a look you will see(its the only difference between the driverside and the passenger side)
