my itermittent section on my wipers is not workin so i thought i would see if they were on a seperate fuse. the prob i have is where is the fuse box other than the one under the bonnet on a glanza as that has very few fuses in it
james
should be one underneath the steering wheel. assuming glanza and starlet dash are the same.
it does take mini blade fuses as opposed to the big ones.
IIRC the wipers are on a single fuse so if you've got all other speeds I doubt the fuse has blown.
What is more likely is that the timer unit on the wiper system is messed up. Might be a blown resistor or something. They are only simple 555 timer type circuits or in some cases built into the relay.
On my golf the computer software controls the wiper timing, but I don' think thats the case on the starlet.
hope this helps
have a nice day
sanj
