Toyota Sera seats
3 sets of interior for Toyota Sera. Seats in brown or blue. Front bucket style seats should easily transplant into other Toyotas.
  • 2 months later...
Would the front's fit in an EP91 uk sr starlet matey? if so how much?
Without being familiar with the starlet seat myself, I can't say for sure, but there is a strong possibility.
£ 75 per pair of seats.
I can measure distance between front and rear bolt holes and the distance between runners if you want.
Ok mate
Well the front 2 holes that bolt the seat to the floor are at an angle sloping forwards. Then the rear left (as you sit in the seat looks to be bolted into the side of the tunnel that runs along the center of the car (if you know what i mean where the handbrake is). Then the rear right bolt is sloping backwards away from the seat.
Does any of this sound familiar?:)
Just had a look at the seats to remind myself.
Two runners, four mounting points.
Front mounting points are angled down.
rear mounting points are flat.
The runners are parallel and the hole centres are 44cm apart.
The distance from the front mounting hole to the rear one is 36cm
Andrew
This topic is now closed to further replies.
