Disc's & Pad's
CoRoLLa_KiD
Just after a decent quote for some new brakes, any suggestions where to get one? Not after performance ones because its only a 1.8 :lol: . So just the standard Toyota ones.
P.S. How do I tell if I need new pad's aswell as discs? :unsure:
If the pads are low the "low pad indicator" spring will be touching the discs and making a squeeling sound whenever you apply your brakes. If the discs are scored or worn down - you can tell by removing the wheel and feeling the disc for grooves where the pads run, it's time to replace discs.
As far as replacing for stock equivalent, you should go gold as we have a couple of discount structures set up :thumbsup:
Even, say, going slightly up-rated with gold saves you loads over going for stock from MrT.
Fit them yourself and you'll save even more (check my how-to in the Wrokshop Submissions section) :thumbsup:
try www.brakesinternational.co.uk :thumbsup:
Not saying anything except for: Goldies can get better pricing than Brakes Intl. :D :thumbsup:
I think I added it up correctly :unsure:
Came to £177 which is alot better than the £231 they told me at a local motor shop
Might have to con my mum into this gold malarkie :lol:
