Fill Me In
vmail
could you suggest good location for the following
2 or 4 CCTV Camera with night vison
ITX PC (just smaller than a ream* of A4 paper)
Battery
location for touch screen
location for GPS mouse
location for WIFI point
*ream of paper is 500 sheets
Cameras, where you want them maybe? Grille at front bumper at back?
PC in the glovebox I woulda thought would be easiest.
Batteries normaly go under the bonnet.
Touch screen beside the instrument panel?
GPS mouse needs to have a direct view of sky really so on top of dashboard.
Wifi in boot?
cheers, will strech(sp) the cables
i bet you could mount the PC in the wheel well under the spare wheel??? maybe?
:lol::lol::lol:
its the 2nd Battery, if it goes in the boot it needs a vent, if under the hood then alot of work is needed to make both batteries fit.
one of the cameas will be near the divers seatbelt facing forwards, will test the other suggestion
nice one rob, didnt think of that
If you want to be flash try fitting the pc in the cubby hole beside the stereo. Then to be even flashier install another one in the passenger side cubby hole for a lan :P
wouldnt fit the PSU and Mainboad are side by side (just smaller than A4 paper)
