I'm thinking of getting an apexi SAFCII, hope to sqeeze out more horses and improve fuel consumptions.
I remember reading somewhere that the MR2's ecu is self-learning, hence you will eventually run out of setting range. Is that true?
Do I need to get the ignition timing done too? In that case E-manage will be a better options.
I've heard about cars getting 20/30 bhp out of an SAFC ..
and the ECU is a learning one, but the SAFC adjusts the values the ECU "sees" so it is fine.
u must be joking for an additional 20/30bhp!!!!
what? It was a mates car, was running very righ on hi boost .. think it went from 280 to just over 300 after a tune from one ..
I installed mine over the weekend but havnt messed with the tuning yet. I wouldnt be surprised if you could gain 20-30bhp tbh..especially on increased boost as thats when the ecu chucks in tons of extra fuel. Leaning out the mixture with an safc at high rpm on the Hi-Throttle setting will no doubt increase power (and combustion temperature!)
Where did you get ur apexi safcII ?? The cheapest I found is £150 from the state.
got it off eBay for £195 from a user calle 5400rpm i think. looks like i couldve saved myself £40!
I like all the graphs on it :ph34r::thumbsup:
I also found it sits nicely where the ashtray goes.
Stu8... you need more gadgets!!! ;) :D
lol, you should see it at night. :thumbsup:
This is ground control calling Major Tom. :D
