Door Handle
breezer
How do you get the door handle off a yaris? Might to to a scrappy sometime and pinch some colour coded ones, or nick some black ones and attempt colour code!!
iv seen inside the door panel, but didnt even want to attempt trying it on mine!!
youll have fun removing them
they are designed to brake if tampered with in the wrong way and have a huge metal sheild around them
That reassuring to know in the event of an attempted break in...
You will be able to remove them mate,
just need to remove the metal shield first
And i think the actual handle is held on with 2 10mm nuts :thumbsup:
hmmmm! i guess if i can get it off a scraped yaris il be able to get it off mine wont i!
better to try on a knacked yaris already!
ricos right its esy in terms to remove, just remove the shild and undo the nuts
the nusts are just on weird nylon supports that shear if your not careful
yes theres like a nylon bush that snaps if you mess with the lock
Theres an easier way
1) find a local bodyshop
2) book it in
3) take it in, they will mask up the handle and paint them
4) couple of hours later they will be done
5) pay up - £40 should cover it
or
1) try fiddling with door handles,
2) graze arms and fingers
3) gnash your teeth a bit when it starts annoying you
4) get mighty P****d off when it starts getting dark and you cant see
5) lose a few screws on the drive
6) add a bit of brute force
7) SNAP!
8) Broken handle :eek:
9) Decide that you cant find a repalcement in a scrappy so you ahve to pay Toyota about £100 for a new one
10) start again!
I know which i would choose! :thumbsup:
2) book it in
or
7) SNAP!
10) start again!
Good point :thumbsup:
