Discs Off Gt4
kimi
this may sound strange but has anyone got a brake disc from a gt4
that you dont want?
it can be knackered i just need one for measurements :thumbsup:
if anybody is going to pod bring it along with you i'll buy you a coffee :lol:
for your trouble :thumbsup:
kimi :wub:
1994 onwards 315 x 32 mm
1990 to 1994 277 x 25 mm
1985 to 1990 255 x 25 mm :thumbsup::thumbsup:
thanx for that ,
you dont happen to know if the stud fitment(the gap)is the same
as the yaris Tsport do you?
Kim,
All the info you ever needed should be here. According to the list most Celicas were 5 stud. but there are ways around that :yes:
FRONT DISC/DRUM - TOYOTA (01-) YARIS 1.5 INC T-SPORT
255 x 20 mm
the thickness of the gt4 discs wont fit the yaris t sport calipers.only if you put worn brake pads in your car would they fit.plus your discs are nearly the same size as the old gt4 any ways. only a 5mm thickness difference.not viable :thumbsup:
its ok i aint putting my calipers on i've got a nice set of four pot
ap's waiting just need to source bigger discs.
thanx for your help anyway
bigger calipers means bigger wheels usually , so if you have 16" or 17" suppose you'll be ok.
ask these guys for advice. http://www.demon-tweeks.co.uk
most ap calipers come as a racing set , ie discs ,calipers, pads ,steel braided brake lines etc.
good luck anyway. :thumbsup:
is this for cosmetics then? surely the brakes are more than adequate on the T sport already aren't they?
suppose big brakes do look nice :thumbsup:
btw if you still want a disc I think I still have an old TRD one knocking around, it's warped to buggery (had a bent hub which ubikd it up) which is quite annyoying since it's only done about 5000 miles. Still be useful for testing fitments etc though.
another place for info on bigger brakes is these guys they can do brake conversion for almost any car you can think of I'm going to see them once i can afford to get the conversion done :D
Hi Spec Brakes
Thanx for all your help and offers of discs think i've got it sorted.
I work at xtreme(formely Ralliart uk) we have sitting on the shelf
a nice new set of AP 4 pot calipers that fit my car but no discs or hoses,
The idea was to fit a bigger set of celica discs,
but i have sorted out someone who will custom make me discs to fit.
Thanx again for helping :thumbsup:
not bad AP calipers and discs for £400 :yes::drool::yes:
Hi Spec Brakes
Which model of GT4 do you have? The GT4 Owner's Club has already sorted out a deal with Hi-Spec for the ST185. The most cost effective route for the ST205 would be some Tarox/TRD/Black Diamond grooved disks and some uprated pads - You'll find it very hard to find the limits of this setup (I never found it at the Nurburgring!)
