Toyota Corola 4afe Engine
starwand
hey,
:drool:
can anyone one give me some help i got the car started, it was just a stupid plug that was out. but now it's started. the car trottles but when i hit the gas it sounds as if the car is dieing out. suffering from low fuel. . What can be the problem? i i can't go over a certain rebbs or it closes off.
Is there any site that gives you the Trouble code meaning for the 4A-FE engines?
Thanks,
please Help :wacko:
Initial thoughts are your TPS is not registering the throttle position. Check the connections are ok on the throttle body.
