Clunking Noise
Radtoy
Guys,
my YTS over the last 2 days has developed a clunking/rattling noise from under the front of the car. It only happens at low speeds and when turning.
I've checked everythings tight and it all looks ok, Wheel bearings seem fine, wishbone bushes look ok (but there is some movement in them i'm not too sure on)
i've checked the shocks, the springs are seated fine, theres no leaks in any of the power steering, in fact I'm stumped as to what it is!
Any help?
anti roll bar bush sounds lik to be
its help on with a U shaped clamp it can actually slide out if youve been belting around
