Doers anyone have a technical manual for the Yaris?
I'm trying to get one from Toyota but there very hard to get they say.
I want to put Speakers in and fix a small dint where some D***head kicked it :(
Its at the rear passenger door and I want to remove the interior part so I can push the dint out.
Any help much appreciated.
should be simple - there are some philips screws to remove - that should give you access to fix that dent - at this time you should figure if the Speakers you want to put in will fit .
Good luck
Ofer
Thanks for the info but how do I get the window roller off safely? After that the cover should come off.
u will strugle to get a manual, if u got any queries then try me as im a toyota monkey!!!
I will remember to bring a bag of peanuts with me at the Beaulieu Meet... I will hide them under my bonnet and you will have to unscrew and tighten things to be able to find the peanuts :D:D:D:D:D
