Cant Get B Disks To Fit Import Gen6
leon1918
went to get my car serviced by my local mechanic and he had alot of problems finding disks to fit the front , back wasnt needed. can anyone shed any light here , its a ss1 st 203 with 4ws 95
it aint that hard theres a choice off two size i should of had later disc on mine cause the engine was the later one but they only had the small disc theres about 20mm diff between them i think any probs ring lloyds garage speak to taff ill have a look for ya 01299 822053 9-6
we had a book of ferodo and also import disks and when the second disk went on and when all secured the pads were locked onto the disk, and i dont think it was a mechanical mistake cos this guy is pretty good, ? any more help
only discs i can find online are sizes for a st202 , import 255 x 25 mm .
uk variant is 275 x 28 mm. hope this helps. :thumbsup:
Just go to your local Toyota garage, give em your chassis number and they can use EPC to find the parts for you :thumbsup:
finally got disks to fit today guys , it says blueprint ion the box and they cost slightly over 70£ each!! expensive but necessary
blue print gear is top stuff. :thumbsup:
yeah , the dics and pads have around 150 miles on them now but are not really sharp, will this take a wee bit of time?
a few hundred mile should bed them in . :thumbsup:
