Corolla 1.6 Vvt-i
Toyosupra[pt]
I need two tires 195 60 r15, because one of them is damaged
I saw the prices of Bridgestone re720 and..
195 60 r15 V -> 107€
195 50 r15 V -> 66€
I think i should buy 4 in this size: 195 50 r15 <_<
They told me that the speedometer stayed with a big error, and gear box with a different ratio (less top speed)
What do you think?
Change tire size or not?
' date='Oct 21 2004, 12:14 AM'] I need two tires 195 60 r15, because one of them is damaged
195 50 r15 V -> 66€
What do you think?
Try this : http://www.miata.net/garage/tirecalc.html
:thumbsup:
What do you think?
Your speedo from about 48km/h will be about 4km/h out (which is not much as all cars have inaccurate speedos!)
However if you 'go down' to a lower profile on the same size wheel for the car you may find it does not 'sit' right and it may feel more bumpy on the roads.
