I've noticed in the last couple of days small drops of oil on the floor where my car is parked. Recently it has began leaking onto the exhaust causing white smoke only at startup. The car also seems very sluggish like its hesitating when accelerating etc. What I wanted to ask is would it be my cam seal gaket as I had this re-sealed by Toyota in late july and then again in august. Also has anyone here had the same problem and managed to fix the problem. I would appreciate any advise. Thanks
It could be just about any oil sealing gasket! You will need to look from the top down rather than the bottom up to find it.
Might be worth checking the o-ring on the dizzy drive. They perish and leak oil out of the end of the engine.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
