Can someone give me the low down on these?
What is available - seem to vary hugely in price.
Do they make a big difference or better off without?
Are they easy enough to fit?
Cheers :)
Cheers :)
What is available , Look on eBay you can pick them up cheap :thumbsup:
they do make a difference, as long as your g/box is o.k. doe's yours go into gear o.k. and they are realy easy to fit . takes longer to take all the bits out to get at it .
if you go onto imoc you can see how to do it..
Cheers :)
Yeah gearbox is sweet still so think I may get one of these on the go.
Do they make getting into gear notchy at all?
I got the TRD short shift kit. Quite costly.
As for fitting it.. can't be that hard as I managed it myself... lol.
Told you it is easy if Jim can do it :P :P :P :P
saying that....
I was left with a few bits once I put it together... lol.
Forgot to put a few bits back. The rubber bit which sits under the white bit ( if that makes sense ), and the clip which keeps the spring bar thing in place to re-centre the gear nob when in neutral.
Will get round to it one day though.... lol.
Some bolts, the bush, 1clip,
not bad you 1/2 back.... :P :P :P
I made mine myself using my original lever and a small piece of metal about 2" long, drilled 2 holes then mounted it on the original lever were the linkage goes then put the linkage in the other hole.
Thus lifting the linkage making the throw shorter.
Easy peasy!!!!!
I also cut the lever down 1"
Its cut the throw down by about 3" forward and 3" backward.
Russ
yeah yeah... show off.... lol :D
Easy peasy!!!!!
Russ
Yes but did you have any Spares left like Jim :yes:
unless you have bits left over no matter what you do.... then you havn't done a proper job.... lol :yes:
ah crap.... loads of bits left over !??!?
Oh well... couldn't have been important then..... :unsure:
Easy peasy!!!!!
Russ
I had the spare bit of lever i cut off!!!!!!
Does that count??????
:lol::lol::lol::lol::lol:
Russ
