Missing?
andy_twincams
Just having props with the rolla wontered if you top guys can help so here it is i started modding the engine first a strip and rebuild with new gaskets rings etc,then the fast road 272' duration kent cams,a power flow full exaust(which sounds evil)induction kit,fse fuel regulator and a race icon chip from super chips(a piggy back unit)but since the chip was fit i started miising when under load??the ht leads are new the rotor arms new as isthe distributor and the chip was changed so thats not faulty??please help thanks :thumbsup:
The exhaust system...
Is it through-flow?
Or
Are there any baffles along the pipe work?
you havent changed your fuel pump to match the cams and intake, the fuel regulator is doing its best to back up pressure along the fuel rail but i think you still need more delivery from the tank.
There is another toyota family fuel pump you can swap straight in with more CFM but i cant remember which it is, sorry.
