Magnecor Leads
Placing an order for magnecor leads, would I need the standard 'push on' boot type connector or special plastic clip type connectors) also would I need 5mm or 7mm ones. Cheers
I would like to know this also as I need a set. '91 n/a
well for original 7mm core models till 93 and 5mm models after 93 there is a big diference, on old Magnecor site there was for 3SGE MR2 only old buth under celica there was model for 93+ MR2 so first check yours model and original diameter of plugs core
here is mine KVR85 Magnecor sparc plugs:
ooooooooooooohhhh... colourful! Nice.
just get the 8.5's then all you need to know is clip or boot, to find this out have a look in your engine bay and see if you have clip or boot :)
What does a clip look like?
What does a boot look like?
clip has the 'clip' bit to get it off you have to pull at the 'clip' the boot one just push on and pull off with no clip fastening. :)
I just have a rubber ring that you pull with your finger. So whats that then?.. boot?
LOL :lol::lol::lol:
What year is it? Early 2's had boot type and later have the clip type. Either way, go fore the 8.5mm ones.
Boot :)
er... when they refering boot or clip. It's the single king lead that they are refering, not the 4 wires from dizzy cap spark plug.
I happen to ordered the wrong one, I then found out my king lead is actually a CLIP type....
I got a 91 N/A aswell, my king lead has a push on clip fastening to the dizzy cap centre terminal, and rubber rings at the tops of the plug leads. So thats boots type I need then yes? Or would we mention what we have to the salesperson to get the right bits?
Mine is that also...
What is a good price to pay for a set? is it cheaper than TOYOTA parts?
ive just ordered some 8mm magnecor leads from fensport today....hope they are the right one`s now after readin this lol
How much?
They should be somewhere between £60-80.
yeah £60ish I think mate. Inc tax and postage. I didnt actually ask for a total price lol..hmm..i should really ask before I buy?
£60 sounds good to me. Go for it. :thumbsup:
Personally guys, I would steer well clear of Magnecor's. They have a bit of a tendency for popping off whilst the engine is running - especially under a heavy foot :ph34r:
You won't find better than the stock leads :thumbsup:
That goes for tubbies or N/A's.
Unless they have improved their design in the last 6 months...
Hi all, just thought it would be worth mentioning Envy Performance are now an authorised Magnecor dealer and we can do 10% off RRP for all Gold members on this item.
Kevin
just out of curiosity how much would that make them then??
yeah.. how much?
Prices are as follows:
..............8mm.........7mm..........8.5mm
90-92.....54.65........54.75...........58.35
92-93.....68.00...........................70.45
94-98.....69.50...........................76.30
HTH
Kevin
:bookworm: Nope thats pretty much a myth or atleast its happened to Very few people ive Had the leads on for 3 months now besides mine are clipped on so a rather difficult feet to pop off :eek:
