Abs Sensor Update
NickMercury
Hi Folks,
in reply to my earlier posting about a failed front offside ABS sensor on my 1998 CarinaE 1.8SE....
I had been quoted £170 by the Toyota Dealer to fit a new one, or £120 for the part alone. :crybaby:
I spent the last few weeks phoning around and dropping into breakers...
and then the other day i found a breakers who has the near side sensor for £25.
Now, the sensor is a kind of epoxy moulded part, and the near side and off side sensors have the wires exiting the sensor on different sides.
But i bought the sensor anyway... :yes:
Went to fit the part, and it fitted no problem. Checked for clearance with the steering at both ends of lock, and it was good. I also cut a corner, by not removing the arch liner, and cutting the wires, and soldering the new sensor in, and then water proofing with heatshrink sleeve...
Works fine now, and saved myself at least £100... :thumbsup:
:o Oh yes, for the record.
The ABS sensor should have a resistance of 1.6Kohms... My failed sensor was open circuit.
Just in case you want to know
Nick :yes:
way to go bro . thats a bit expensive though for a front sensor , i got mine for a 1995 celica for just under £ 90 each . the rears were £ 129 and £ 120 . :eek:
