Surf 91 SSR, rear window not working everything else seems to work, have found fuses for everything but windows...Can anyone tell me where they are please..
Thanks ;)
You will find some under the bonnet and some in the drivers side footwell, also you will find a control unit stashed behind a panel in the rear.
Some people have found that they have pressed the window lock switch on the drivers door by mistake.
Also try www.hiluxsurf.co.uk
yep been caught with window lock before but not this time....;(
The fuses under bonnet seem to be for front headlamps and fans, fuses in footwell for rear lights/ciggie lighter/ Radio...
But still none for windows....They must be somewhere????
