Broken Convertible Roof
Mezza
I have managed to break the main support strut that supports the roof of my convertible. Has anyone else had any experiance in getting this repaired ?
You can replace it by phoning Toyota Celica Breakers, number is somewhere on this forum but I've posted it so many times I no longer have it to hand !
Toyota Breakers (Celica) Cornwall
TCB Performance Parts Ltd
Florence Road
Kelly Bray
Callington
Cornwall
PL17 8EG
Tel 01579-383879
You're better of replacing it with another secondhand one. Welding the alloy they used is a bit **** since it's **** steel. Even a dillon torch has trouble and they are the puppies plums.
Should be cheap.
Ever tried changing a rear window motor on one? Did one the other day and my monkey hands took some punishment. !Removed! must have little hands.
