Dints
breezer
I have various dints around my car bodywork!
i have two medium sized ones, jus about size of fist, as if someones been pushing my car - theyre on the boot!
i have a slightly smaller one on rear right hand side.
i have 3/4 very small pointy dints around the drivers side door
any idea how much itd cost to get them all took out?
and how do they do it?
cheers
The bigger ones will probably be around £60!! They either tap them out and use magnets and then give respray if necessary. Or they replace the bonnet (which is more!!)
The little ones can be pulled out with magnets, they wont be much to do i wouldn't have thought. I know a place in leeds that will do your first three minor dings or scratches for £40! Nice place!
Im sure other methods are used, but these are the ones i know of!
The body shop i used to work in charged around £20 - £30 per panel for paintless dent removal.
Dont think you would get it done much cheaper than that
I've aquired a bit of a lengthy scratch on the drivers door :( . Just have to T-Cut every wash.. you can't see it then! :D
yep a respray jobwith the panel beater if the scratches are deep or bad as to be really noticed cost ya a bit of money though if not too bad t-cut them
