Corolla Intake Pipe Kits - Special Offer
FunkyStyling
Just got in stock - selling special offer to TOC members.
Corolla 90-93 intake pipe kits. Kit includes intake pipe and fittings. This will allow you to fit any 3" clamp-on filter (like a K+M) to your car. We can supply a suitable filter if you need, one. For the intake pipe we're asking £40 delivered within the UK. See below for pic. If you're interested then please mail sales@funkyproduct.co.uk
This is a limited offer of only 3 units - once these sell the offer will close. Be quick!
How would this fit to the throttle body?
Would you supply a rubber gasket or somthing?
I take it the filter end would also need a gasket of sorts or does your filter slip over the pipe?
Would the filter also have a facility for the other sensor?
What are filtration properties of the filter?
Is it a wet or a dry type filter?
Performance increases on the filter?
A rubber couple is included in the fitting kit
The filter slips over the pipe and 'clamps-on'
I'll check what holes the pipe has when I'm in the office on Monday. It does have one sensor hole as per the pic, I'll check to see what else it has.
Depends on which filter you fit to it. Any 3" clamp-on type will fit with this intake pipe. If you wanted one from us, you can see them on our site and we have dry ones similar to K+N, or similar to Blitz, or similar to HKS. All will work with this intake pipe.
hey would it fit on a 90' GTS cause the intake is in a dumb place?
Post up a pic of the engine bay and I'll check it out.
C
