hi all,
has any one got a paseo 5EFE ECU for sale as i have fitted a 5efe engine but the ecu that came with it is knackered and the place where i bought it have told me it was sold as seen so therfore no refund. the engine does run on the 4efe ECU but it runs very lean. if i don't get it sorted soon i think my head gasket will blow
all help and advice welcome
thanks
John
I have a 5E-FHE ECU, 2 plug type
cheers mate :thumbsup: but wouldn't i have to modify my loom to fit that?
if it will fit how much would you want for it?
Yes you would have to modify your loom. There are 2 plug and 3 plug ECUs. I know EP91 turbos use the three plug ECU, and the 5E-FHE and 5E-FE are available in 2 plug and 3 plug ECUs
Sera 5E-FHE - always 2 plug
Starlet Turbo EP82 4E-FTE - manual, 2 plug, auto 3 plug
Starlet Turbo EP91 4E-FTE - all 3 plug
Paseo / Cynos - some of both types.
Andrew
how much for the ECU?
  • 3 years later...
hi all
how the rpm runs on this engin 5efe 2 plug type
thnx
