Heater On New Avensis
matty2767
i have read the instructions but cannot seem to get the system to work. according to the manual the outside temp has to be <8 degrees and the heating set to max. if i press the button near to the mirror adjust switch the cabin is supposed to heat up very quickly.
has anyone got this to work? if so am i doing anything wrong?
thanks
matthew
right ok
outside temp no greater than +8
temp control set to max
blower set to max
engine coolant temp below 70 deg
basically first thing in the morning
right the slight catch if you have been running with the aircon on
the warm up is set low until the moisture in the heater unit has dryed up
take for a run tonight warm it up with no aircon and try the power heater
in the morning :thumbsup:
