Hi All
I recently just bought Mk3 Supra it's been wicked so far apart from the rattle boot.
But my problem is this now it's colder I turn the ignition nothing happends plenty of clicky with the relays but the engine does not even attempt to turn. After turning the key a few time kind of priming it it finally starts to fire up.
I have change the Battery But I'm thinking starter motor or ignition switch anyone have ideas or have had a simular problem?? :crybaby:
take the live off the starter , clean it up and copper slip it or grease it , see if that helps you. :thumbsup:
