Deciphering Codes
kentc
In looking at vehicle ID plates on the firewall, the type transmission is listed (ie T50) along with the VIN number. Does anyone know whether the trans ratio is part of the VIN or is it stated elsewhere on the vehicle??
if you can give me the chassis number i can look for you on the toyota epc. :thumbsup:
Thank you maleborn1967: The model is RA42L-BLMQSA and the frame no. is RA42-102093. I'm looking for a close ratio trans for our Bonneville Salt Flat car. Shifting into 4th at 9,500 rpm, motor drops to 6,300. Motor peaks at 8,000-8,500 and cannot recover at the end of the run, getting back to 7,000 (140 mph). Consequently may have several VIN's to look up by the time this is over. Just what reference are you checking?? Thanks for the time,
Kent
sorry man those numbers dont come up on screen ,my program only covers uk cars from toyota , the jap one is the one you need , i'm getting it soon maybe its on there. i use the toyota epc program. :thumbsup:
This is a box from a 1978-1980 Celica GT with a 20R engine, right?
If so, then as far as I know it should have a W50 box with the following ratios:
1= 3.287
2= 2.043
3= 1.394
4= 1.000
5= 0.853
R=-4.039
You do however mention a T50 box, I thought these only came with the T-series engined Celicas, and not available in the US. Anyway, gear ratios for the T50 are:
1= 3.587
2= 2.022
3= 1.384
4= 1.000
5= 0.861
R=-3.484
Cheers, Yves.
