Compression
jdman687
dunno if this helps , but the ratio's for a 182 are, your engine produces 130 bhp
Displacement, cc 1998
Engine model 3S-FE
Max.power (Net), kw(PS)/rpm 140 ps (102.97 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 19.0 kg*m (186.33 N*m) / 4400 rpm
Power density 8.79
Engine type Serial 4 cylinder DOHC16 valve
Engine information
Fuel system EFI (electronic fuel injection)
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) No
Compression ratio 9.5
Bore, mm 86
Stroke, mm 86
