Strut-bar?
Oli
Is it worth getting a strut brace for my Yaris TS. I can get one delveried for about £70. Will i notice any differnce with standard shocks & springs.
Thanks in advance
Hi oli Well if you can get a strut brace for £70 pounds that a bargain. As for the handling you will only notice it when you push the car really hard through the twisty bits. But on normal everyday driving you wont notice. Will you be fitting it yourself? As you might have to do a bit of modifying to get it on.
Also if you over tighten the strut you will cause tyre ware!!
jerry!!
jerry can you explain this, the brace needs to be bolted down good, kind of makes it irrelivant if the suspension or brace has movement
Only trouble with Strut bars is if you have a collision on one side...all the energy is also transfered
to the other...a small knock...heavens forbid! can lead to the motor been written off as the chasis ends up twisted.
Vipes
Yes - hence ask your insurance company how much it will increase your premium if you add one - I asked them and i guess they sure as hell know that info also!
Steve.
but they also help hold the front, or rear together i an impact aswell
bit of a give and take really, but you dont think of an accident when your thinking of handling.
before considering a strut brace though, look at everything else in the suspension.
have you lowered the car
do you have uprated anti-roll bars
have you uprated the suspension bushes
have you got low profile tyres
only when the suspension movement has been limilted , then will you feel the best benifit from a brace
