im stuck on how i wire it to da ignition coil,cud sum1 tell me ow to do it??
the starlet has built in electronic ignition, so the sender wire is pretty hard 2 find...
but i'll tell ya which one cus im kind...
look at the distributor cap, there are 2 wiring blocks behind it (kinda attached to it), its the green wire on the bottom block!!! :yes:
Rich.
This could do with been a sticky as it its quite useful
As well as the interior light one
aaannnd the maybe even tht dash light conversion rough guide i gave
Just a thought
tried it and it wnt work :angry:
il have 2 c a mechanic.dats not a bad idea captain starlet,but nevr paint dash bulbs bue coz u can barely c da ********n dials!im gona have 2 geta black light.
thats defineately the sender wire thou. i've got mine wired up 2 it!!!!!!!!
thats odd.
Rich.
an ive painted my dash bulbs an their great,two coats, jus make sure u you use GLASS paint,thts heat proof/oven drying ,got mine from a craft shop
i used glass paint,but even after 2 coats da white light stil came frew! :angry:
ow long did u leave dem 2 dry 4,on each coat??
about 2-3hours ill get u the colour i used an type on here,im at ma gf's tho at the min,but wen i get back ill put it on here
